BurbMan
Oct 23, 2020Explorer III
Anything is possible! The biggest challenges are having a dry place to work and equipment to remove the slide. Larger slides are installed/removed with a forklift. I was able to handle the slide removal on my Lance renovation with a couple of buddies because it's only 18" deep and about 6' wide.
Then you have to deal with opening up the walls to handle the installation and framing, and also the wiring and switches needed.
Hard to see the value of this for the time spent unless you are retired are looking for something to do besides play golf....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
