4X4Dodger
Feb 02, 2015Explorer II
GlennLever wrote:
I installed LED taillights and had a lot of problems with them burning out, I eventually went back to regular filament bulbs which solved my problems.
LED taillight upgrade which failed
From your photo there seems to be quite a bit of rust, corrosion and oxidation on the bulb holder. This very well could have led to the failure. Some WD-40 and some emery cloth will work wonders on that receptacle.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
