Steve_83406
Jan 04, 2017Explorer
I don't know if this will help... I have a 1991 Prowler 24C. I recently replaced the converter with a Power Dynamics PD9245C. Then I got a bug to put in a surge protector. Rather than letting a thief make an easy $100 by stealing a protector off a power hookup, I decided I needed a Progressive Industries EMS-HW30C hardwired protector. To install it I would have to pull my Magnetek power center so I could access the space behind it. While I had it out, I changed out the 9-circuit 12V DC fuse panel for a new Parallax 12-circuit panel. Below is a picture of the internals of the power center. There isn't much in there, a few circuit breakers and some connector strips. I changed all the feed-through protectors for the wires, cleaned up the wiring a little, and added a small notch to allow easy access to the first fuse.
My 2 cents? Only change the box if you have nothing better to do!
Steve
Steve
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
