cs2kplus's avatar
cs2kplus
Replacing 4 tires (jacking up)
Need to replace all tires. Where do I jack up? Do I do one tire at a time? See attached view of axles. Also see jack instructions. Says to jack on axle - which I hear you should not do? Then that would mean doing one tire at a time. My cousin said he would jack in middle between the 2. Not sure where jack would go. While all this jacking is happening...what about the a frame tongue? Is that on frame jack or on tow vehicle? I've see these big chocks you can ride up on to get the one tire off the ground. Even saw a guy do it with would and then jack up the front and freed to front wheels. Not so sure the reverse would work. HELP!!!
jack-instructions
under-rv
  • Tom,
    I used "image" and it asked for url. So I stuck pics on website and pasted url. I've seen other people do this...why do I need a url to add pics??? How is this done - maybe I am doing something wrong?
    Wayne
  • Pictures didn't come across.
    You are right to be cautious though, as bending the axle will throw off the alignment. You are safe to jack under the shackles at the leaf springs though.
    I leave the heaving lifting to Discount Tire, supervising the boys to be sure they are under the shackles.
