turbojimmy
May 19, 2018Explorer
It shouldn't be that bad. I replaced the non-functioning oven in my '84 Allegro with a new Atwood range (gas, of course). I got it from a scratch-n-dent seller on eBay. It had been removed from a new RV because it had a couple of scratches on it. I don't bake a lot, but I really don't see the difference between it and my residential gas oven in my house (other than size, of course). My primary use is frozen pizza, though, which doesn't seem to care too much where it gets cooked.
Anyway - there are a couple of things to consider. If the rig you're considering has an electric cooktop you're going to need to bring gas to the area. It's basically just a U-shaped cutout in the counter. They hang from the countertop and are secured to the cabinet framing on the front with wood screws. They don't go the whole way to the floor so you're going to want to fabricate some sort of drawer or cabinet underneath it. My furnace is under the range so there's a vented access door directly beneath the range.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
