rvten
Jul 05, 2013Explorer
Replaced our carpet. Left the carpet under the slide.
Just cut the carpet and leave enough to put a metal trim piece down. After you put in the flooring you want.
I used peal and stick vinyl squares.
Make sure you get all the staples off the wood floor.
If you really insist on going under the slide.
You have to tilt it outward to get under it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
