Alpenliter
Jul 05, 2013Explorer
when you remove the carpet from the slide, you may find, as I did, that the manufacturer installed a fascia board on the leading edge of the slide. By removing this, you will gain additional access to the area under the slide for carpet removal and laminate installation.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
