RLGetman
Jul 15, 2013Explorer
Couple of points on this topic: 1) watch the weight. Replacing original carpet and vinyl with floor panels can add 500+ lbs. 2) You can purchase teflon sheets to place on floor/slide contact areas to protect during slide retraction. 3) Use high quality adhesive as cheap adhesive will leave you with bubble areas to repair 4) Slide carpets can also be replaced with flooring as well if you allow for interface (send email in private message if you want how-to and pictures).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
