- jmckelvyExplorer
Yeti plus wrote:
If you use Bargman 47-84-410, all you have to do is take the existing lens off, remove lamp and put the new unit in place. No extra wiring needed.
That is what i did to the TC and the light is far better.
Brian
I did this also on my AF990.
They have two advantages over the incandescent bulbs. First they are considerably brighter particularly the brake light function. Second the brake lights are pretty much instantaneous with brake application allowing following drivers a few extra milliseconds to respond. - Cummins12V98Explorer IIIOne of the BEST mods I have ever done was replace the entire 3 section Bargman incandescent assemblies on my 32.5 Avion Platinum with the exact LED replacement.
I was SHOCKED to see when I turned on the blinker people actually noticed and mover over. Of course not all but MANY more than before.
On our Mobile Suites it came with a yellow light out of three on each side as the blinker. I want ALL lights to blink as they did on our previous DRV. So I removed the electronic controller and the yellow light and replaced with red and now all my lights blink as they should. I did have to redo a bit if wiring also but not much.
People have no issue seeing these! I turn on blinkers wait if no response I give a courtesy tail wag still no response I slowly start moving over. Life is good!
OH the LED backup light mod below is AWESOME also.
- westendExplorer
packnrat wrote:
For your RV, buy replacements online. There are many vendors on E Bay. I'd suggest to buy warmer color models in different lumen output, if possible. Lumen rating, even by mainstream suppliers, is different by vendor or within vendor.
i just drive them, someone in the shop does the buying. and said for some only dealers and have them and need wait for them to come in.
sure might get most online someplace. maybe even cheeper.
but seeing as most of the fleet here is under warenty. ( 75 trucks).
and we are just one of 120 dcs ( varied products at each of them) around the country. - packnratExploreri just drive them, someone in the shop does the buying. and said for some only dealers and have them and need wait for them to come in.
and we are just one of 120 dcs ( varied products at each of them) around the country. - SoundGuyExplorer
packnrat wrote:
... but i am thinking about the lights in side my coach.
just never have fresh beef under led lights. ( color spectrum is off) meat look sick bad.
Incandescent bulbs typically run ~ 2600 to 2800 degrees Kelvin, the LED versions I'm using inside my trailer are a close 3200 degrees Kelvin. The light is "cleaner" but still quite warm, unlike cold light LEDs which typically run 5000 to 6000 degrees Kelvin.
Fresh beef, anything, looks just fine. :B - jplante4Explorer II
packnrat wrote:
we use leds on the new tracters and trailers at work.
what a joke.
first: dealer only items. always on back order.
gone are the days of universal fit parts.
The trailer manufacturer did not create the LED lights they put on their trailers. They got them from some supplied, whether NTP/Stag, eTrailer or Keller Marine. Probably directlry from Bargman. You can go to those same distributors and get the lights. - packnratExplorerwe use leds on the new tracters and trailers at work.
what a joke.
second: they fail often. do not last anywhere as long as normal lights.
third: cost five times as much.
fourth: way too bright can be confused with the brake lights.
fifth: less current draw = easer to have a curent fail cause less is required so less needed to interfere with the flow of electrons.
yes this is in a commercial setting the equmpment is in use 24-7-365.
yes i run them on my motor bike ( makes little juice), would never just replace them do to cost . but i am thinking about the lights in side my coach.
as to my running lights thinking there, but cost says wait.
and keep at least three or four spares on hand. do not buy the cheap ones as they are pure junk.
We've been using 1157 type double filament bulbs since I was a kid in the '60's for tail/brake lights. "Work Fine, and Last a Long Time" Cost about fifty cents apiece
austinjenna wrote:
I dont really get it either on replacing the outside bulbs with LED's but to each their own. I think I replaced one bulb in like 15 yrs.
I replaced an incandescent bulb on our current trailer last summer - first bulb I've ever had to replace on any trailer we've owned in nearly 20 yrs. :B
Think I'll save my $$ and just stick with what I have because they work and they're legal. ;) - austinjennaExplorer
I dont really get it either on replacing the outside bulbs with LED's but to each their own. I think I replaced one bulb in like 15 yrs. - DiskDoctrExplorerBrighter and more modern. Resealing behind the lights when you change them and no more burnt out bulbs.
It's a nice DIY upgrade for those so inclined. Nothing wrong with taking some pride in your rig :C
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
