jmckelvy
Jan 21, 2018Explorer
Yeti plus wrote:
If you use Bargman 47-84-410, all you have to do is take the existing lens off, remove lamp and put the new unit in place. No extra wiring needed.
That is what i did to the TC and the light is far better.
Brian
I did this also on my AF990.
They have two advantages over the incandescent bulbs. First they are considerably brighter particularly the brake light function. Second the brake lights are pretty much instantaneous with brake application allowing following drivers a few extra milliseconds to respond.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
