Dutch_12078
Apr 13, 2016Explorer III
The internal fuse in the microwave in our previous coach also blew. Or at least that's what I thought. After removing it though, and finding that a replacement fully restored normal operation, I took a close look at the inside of the fuse with a handheld 100x microscope. It quickly became obvious that the fuse element had simply detached from one end cap rather than blowing from an overload. I suspect vibration was the real culprit, possibly combined with a fuse that wasn't assembled quite as well as it might have been. In normal stationary residential use, that fuse may have lasted years longer.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
