Teacher_s_Pet
May 20, 2017Explorer
Most AC units consist of upper and lower components. I had to change out a upper AC section due to the loss of a compressor once. I bought the upper unit of the same brand and size, removed 4 bolts clamping the faulty unit to the roof, then unplugged lower unit. Replaced the upper unit with new foam roof gasket, plugged in harness and replaced bolts. I had a neighbor with a forklift to raise and lower the AC unit, which made the job easy.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
