qtla9111
Sep 08, 2015Nomad
TNGW1500SE wrote:qtla9111 wrote:
Thanks for the answers. I want to remove it because it never gets used. It's too big for the unit, makes too much noise and causes the trailer to drone or vibrate. As mentioned in an earlier thread, I want to install a mini split or highwall on the back bumper. Less btus and much less noise.
Example
Might be ok but I'd worry about a mini split being damaged by road vibration. They are made to be mounted and not bounced down the road mile after mile.
I've given that some thought too. There should be a way around that. Minisplits are very reasonable here in Mexico. I just bought a 1 ton for another bedroom for $199. A 110 3/4 ton should be about the same. A roof top A/C is $500 or more? I would downsize the roof air just to keep it simple but they don't make the 7400 and 9000 btu anymore.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
