GaryGus
12 years agoExplorer
I used a heat gun on low setting and also used up two 3M wheels to remove all of the decals on my unit. It is a slow, tedious process, but works well with a little patience. I used Goof-Off to clean up any glue residue. You might want to test the Goof-Off in a hidden area to make sure it doesn't damage your finish. I then tried to put the front decal on myself, and I failed. It takes two people to do it right, plus you're off the ground and trying to do several things at once.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: 1 day ago
