Steakman's avatar
Steakman
REtro Fitting Slam Latches to my 5'r
First let me apologize for not putting up a pic or two on this post...I will do that when I get back home on days off.
However: I just last week added two of these to my main storage compartment door and it was actually quite easy. However because of the location of the holes from the OEM thumb latches, I cut my holes about 1/4" above where the thumb latches were. To cover the holes I used those automtive push connectors that are used in so many applications in a vehcle these days..with a bit of "Goop"...wiping off the excees once it dried.
The latches were easily installed: Using the gasket of the outer section I traced with a scribe the outline of the hole - drilled into the part to be removed with a 1/2" bit and then with a small fine bladed saw bit, used my jig saw to cut out the hole. Then just a simple matter of putting the three parts together front and the two backing parts with 4 screws.
The latch itself (the part that hits the strike), was pretty much at the same elevation as the aluminum strip that goes around the door opening due to not wanting to have a 1/2 round goofy hole had I gone lower. To ensure I had a solid surface upon which the latch could close onto, I cut some 1/8" aluminum about 3 inches long-deburred and about 1/2" higher than the rib and inserted that in between the rubber gasket and the existing aluminum rib. A couple of small screws and it wont move.
I used one locking latch and one non. Quite happy with the result and it does indeed "slam" closed...beats the daylights out of those pesky thumb latches.!
Pics to come... Up here in Canada I paid $55 for the locking and $30 for the non (from an RV Parts Dealer)... No doubt those of you south of the 49th can get them much cheaper.
I plan on doing the whole unit where practical.
Cheers,
stk
  • Hey Steakman, did you see the article in the latest issue of Trailer Life. they showed an installation of shocks on TT axles. Might provide the impetus to get going on that mod.
  • Yea, I only did the main Storage bay on the Door side and the front...on my main storage bay opposite side, its a set of vertical doors..and doesn't really lend itself to retro-fitting. Am pretty happy with the results. Next mod will be the addition of a couple of sets of shocks on the axles from Lippert.
    Cheers,
    Stk
  • I like that, especially along the front. I saved your pics for future study and copy.
  • Guys...sorry bout the delay...been on Vacation for a couple of weeks.
    Cheers,
    Stk
    Moderator edit to re-size pictures to forum limit of 640px maximum width.
  • Winged One wrote:
    Looking forward to seeing pictures of this mod.
    Ditto??
  • I shall do so on Friday morning.! (If I get time...leaving for the Shushwap in BC around Noon after last minute runnin around..!!)
    VACATION..!!
    As an aside. My Rig is as noted in my sig: 2011 Coachmen Chaparall (Forest River Product). From what I learned from my friend at the RV Dealer I have used over the years, the doors are pretty much identical throughout as far as thickness is concerned. There are two types of latches available. Watch out that the outside portion has a gasket on them..I was also offered some with out gaskets and did not like the idea of using them for obvious reasons.
    But I did take a look at an OEM installation while I was there and they have made changes to accomodate these new latches. I am not sure if the doors are somewhat thicker or the latch mechanism is deeper ...but they have added an aluminum extrusion of some 2" that slips over the Alum rib towards the inside of the compartment to act as a strike.
    Yet when I tried to utilize this extrusion..my latch didn't even come close to where it would even go over this extrusion. So the latch unit itself must be somewhat deeper than the type I bought...or I'm just too old and senile to figure out what they did..! LOL
    I did find it a good thing to empty out my storage compartment and crawl in from the opposite side to make sure that things were going to work.
    You'll see what I mean when I post the pics.
    Stk
  • Great idea. I hate those thumb latches. Please do post some pics when you get a chance.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Jan 01, 2026
