Bob Vaughn wrote:
93Cobra2771 wrote:
MIght be worthwhile to give their tech dept a call and see if something is amiss. Should not be that difficult to install...
I did contact them and was told to grind down the insert so they must know that they cast some too thick.....
I got an air hammer from Harbor Freight and ground down the chisel that came with it till it was flat. I then climbed under the truck and squeezed the trigger and in less than a second the tab moved the 1/8 of an inch and bingo it was in place and I could start installing the air bags.....I am too old to be scooting around on my back under a pick up truck. But I got all the parts installed and now my bags are installed and full of air.....
