Golden_HVAC
Dec 19, 2015Explorer
Hi,
I would not put them on the front to catch 'extra wind' as that might rip them from the roof.
Driving at 55 will have more than enough wind over them, no matter where they are mounted. What I did was put rubber roof sealant under my mounts, and then put in 3 #10 screws through 3/16" holes in a 6" long bracket made from 2" angle aluminum.
I located the mounts so they will be under the panels once the panel is in the travel location.
My front panels are over the drivers seat, and I can hear wind going under the panels while on the freeway. IMHO they are getting way to much air, but moving them back 12" is not really practical, as they would then be to close to the antenna's.
This is my front pair of panels. 120 watt mounted on a curved roof, 102" wide.
This is the mount it is held on with three rivets into the frame, and then the bottom half is 6" long aluminum, with nutsert in the upper piece, bolt you can not see from the outside edge pointing inward.
This picture shows the bigfoot panel mount sold by RvSolarElectric for $35 a set back in 1994. I wonder what they cost today?
This picture shows the panels tilted while I was working on the roof.
Good luck,
Fred.
Good luck,
Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
