jjrbus
Dec 06, 2017Explorer
I had often read about using Barkeepers Friend on an RV and and waxing with Zep floor finish.
Not being one to trust what is on the net without some research I found that Barkeepers Friend is a mild abrasive with oxalic acid, neither of which should harm anything on a fiberglass RV. Removes oxidation and so far all stains.
Wear gloves! I follow directions and apply with a sponge and the results are great, even leaves my 23 year old caulk looking fresh and clean. Take extra care rinsing, the residue does not want to come off. It is a bit of work so I am only doing one side at a time.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
