Veebyes
Dec 08, 2017Explorer II
Barkeepers friend is good stuff but expensive for the job. It also works well on brass.
For badly oxidised gelcoat best to use a compound intended to remove the oxidation. 3M has 3 grades of compound. The most abrasive is very gritty. Not sure if I'd use that on thin RV gelcoats. Maybe use the medium, then the fine. Finish off with a good sealer or wax such as Meguires Flagship. Without protection that hard earned shine will disappear in no time at all.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
