wmoses's avatar
wmoses
RV Wireless TPMS Systems - which one is preferred
I am presently in the market for the subject system and would like to know which ones are preferred by those of you who have them and why.
I note that there are systems by Tireminder and TST and others (including what appears to be cheaper systems on eBay etc.) but the Tireminder and TST seem to hover around $300+. I don't really have a problem paying the money as long as I buy once, so I want something that does what it is designed to do and for a reasonable lifetime.
I also want sensors with replaceable batteries - not interested in replacing the whole sensor when the battery runs out. I only need 4 sensors since the truck has its own TPMS.
So what say you?
  • Excellent replies thus far! Thanks.
    Ron - Why is it imperative to have metal stems? Only thing I can think of is galvanic corrosion action in way of the threads. If that is the case then as long as you get similar thread metals you will reduce (can never eliminate unless you get exactly the same material) the corrosion.
  • +1 for the TST system. 3.5 years on ours w/out any issue.
    I wouldn't for a second consider a system that didn't provide temperature monitoring too (the pressure pro doesnt). Monitoring the temperature will alert you to more than just a potential tire failure - it could be a sign of sticking brakes (over use of brakes) or bearing failure.
    I to use the (screw on) user replaceable battery sensors. Ive been able to buy batteries for a little as 34 cents a piece (including shipping)....I leave the sensors on 24/7 (on both the coach & our jeep wrangler/toad). You can extend the battery live by removing them - since they only transmit when screwed down tight.
    I find that batteries last about a year, sometimes slightly longer.
    they offer, flow thru sensors, non-user replaceable batteries, and in tire sensors (the factory replaceable battery units reportedly last 5 years & then are returned for replacement at about 20 bucks iirc).
    the peace of mind of any TPMS systems is HUGE.
    I was spending a lot of time dragging equipment out just to CHECK the tire pressures....most times i did this unnecessarily (didn't need to add any air pressure)...and too many times i just didn't bother to check the tires (BAD)....now all i do is turn the monitor on & only then (if needed) do i drag out a hose!
  • TST 507 with replaceable batteries. Going on three years now, great system. Would buy it again if necessary.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    TST and Pressure Pro have a big following. There are some new kids on the block too. I have the TST with the replaceable batteries. I paid about $250 4 years ago for the package with 4 sensors. So far it's been great. Whatever you do, make sure you install metal valve stems.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,384 PostsLatest Activity: Aug 06, 2025
