jplante4
Oct 28, 2017Explorer II
I have 450 aH of battery and 200 watts or solar. I don't run the microwave or electric coffee pot when not hooked up, use the inverter to run the TV a few hours a day and run lights at night. I start the genny in the morning and the Xantrex 458 2000 watt inverter/converter tops off the jars in less than an hour. The initial draw can get up towards 100 amps DC.
Make sure you get a multi-stage charger. I'd lean toward an 85 amp job. Maybe this.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
