azrving
Oct 29, 2017Explorer
Also, if you look at a 120 volt AC device and it says that it uses 2 amps when you run it through an inverter it will be pulling about 20 amps DC plus whatever your inverter is using which could be .5 an amp. If you want to avoid an inverter you can charge your phone or run a laptop directly on 12 volts with the proper adapters and avoid the inverter losses.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
