SoundGuy
Feb 13, 2018Explorer
lawrosa wrote:
Upon a few tests with 6 gauge wire and a andreson plug tied to the 40 amp mega fuse, the fuse would blow.
I did the same mod several years ago so I could load support my single G27 trailer battery with my Avalanche but since it didn't have an aux battery I pulled directly from the truck battery with it running. I used 10' of 4 gauge booster cable for minimal voltage drop and that worked well ... what didn't were those same Anderson SB-50 connectors it looks like you've used, which burned & melted. I recently bought a new 4 gauge booster cable and this year will be load supporting my new G31 AGM trailer battery with my Silverado but this time I won't be using those d***** Anderson connectors but instead will clamp directly from the truck battery and truck chassis ground. I still have those Andersons and can take pics if you need proof ... JMO but I'd get rid of them before yours too melt.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
