lawrosa
Feb 13, 2018Explorer
I used these adapters with my old set up. I use one now on my new set up to attaced to neg battery as I couldn't find a good ground close enough.
Sourcing properly mounted fuses was problamatic hence why I mounted the 100 amp breaker..
The chevys also use the ad244 145 amp alternators... Very good..
Not sure if and when they stopped using that model.
Side terminal to 3/8 stud
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
