theoldwizard1
Feb 14, 2018Explorer II
Well ... after reading that WHOLE description, this charging system is more SOPHISTICATED than any others I have seen ! (Of course, I have been retired from automotive engineering for 11 years.)
Your system is capable of a very high voltage, up to 15.5V !! Extended operation at voltages above about 14.5V will kill your vehicle battery !
The "system" sees a very large load, so it kicks up the idle and maxs out the alternator field. This is what you want, but you might not like the results. NOT ALL CHARGING SYSTEMS WORK THIS WAY !
As I said earlier, you are comparing current flow to water flow and it does not exactly work that way. My recommendation to you is, get bigger TRUE DEEP CYCLE batteries (if you go bigger than golf cart batteries to costs goes way up) and get a 12VDC CPAP.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
