CharlesinGA
Feb 15, 2018Explorer
Anderson makes larger, heavier 175 amp connectors. You need to be using those. The 30 amp connectors are not enough.
Will read thru this completely in a moment, but it seems that using something like THIS Surepower Battery isolator, along with some 2 gauge welding cable in plastic jacketing and run along the frame rails, and a 175 amp Anderson connector at the rear bumper, would allow the trailer batteries to charge just like most motorhomes do.
Charles
Charles
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
