ReneeG's avatar
ReneeG
Sewer Hose Storage
When we got our Bighorn, it came with what is called a sewer boom. The concept was good in that it contained the sewer hose while it was connected semi-permanently, and when you needed to dump your tanks, you simply swung it out. Problem was that you could not attach a clear short section for monitoring the emptying of your tank. So, we removed the whole thing. Then we were faced with how/where to store the hose. We kept it in a clear storage bin and that worked for awhile but it took up extra space in the storage bay. Fast forward and DH installed a storage compartment for the hose. He mounted in on the side, using black PVC piping that he drilled holes in top and bottom for air circulation and drainage. He fastened a screwed on lid on both ends, with the end closest the drain valve angled for easy removal and additional drainage. Each end cap is attached with a short chain should it come either undone by itself, we won't lose it or forget that we removed it when using it hence leaving it behind somewhere. From the angle of the photos it looks lower than the frame but in fact it isn't and is higher than the lowest point of the drain valve. It looks really sharp.
Side view:
View back to front:
View front to back:
View down low and close:
Moderator edit to re-size pictures to forum limit of 640px maximum width.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Dec 31, 2025
