ReneeG's avatar
ReneeG
Sewer Hose Storage
When we got our Bighorn, it came with what is called a sewer boom. The concept was good in that it contained the sewer hose while it was connected semi-permanently, and when you needed to dump your tanks, you simply swung it out. Problem was that you could not attach a clear short section for monitoring the emptying of your tank. So, we removed the whole thing. Then we were faced with how/where to store the hose. We kept it in a clear storage bin and that worked for awhile but it took up extra space in the storage bay. Fast forward and DH installed a storage compartment for the hose. He mounted in on the side, using black PVC piping that he drilled holes in top and bottom for air circulation and drainage. He fastened a screwed on lid on both ends, with the end closest the drain valve angled for easy removal and additional drainage. Each end cap is attached with a short chain should it come either undone by itself, we won't lose it or forget that we removed it when using it hence leaving it behind somewhere. From the angle of the photos it looks lower than the frame but in fact it isn't and is higher than the lowest point of the drain valve. It looks really sharp.
Side view:
View back to front:
View front to back:
View down low and close:
Moderator edit to re-size pictures to forum limit of 640px maximum width.
  • That's a nice one...but, don't you just hate kneeling on that gravel while you do a project like that...:@
  • Very nice! And the PVC should be strong enough to withstand any rocks the tires kick at it, too. That's one thing that concerns me about the vinyl fencepost I used...it's somewhat protected but if a big rock hits it, I might end up with a crack.
  • Thank you. I forgot to say that not only does it contain the hose, but a spare and the bayonet and the piece that connects the two for a longer hose.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,387 PostsLatest Activity: Aug 18, 2025
