wintersun
Aug 03, 2013Explorer II
I expect the transmission fluid temp to be 60 degrees hotter than the ambient air temperature. The trans is OK with fluid temp up to 220 degrees though even on long grades in 115 degree whether the highest temp I have seen on my Allison transmission is 178 degrees. The absolute maximum temp is 262 degrees before the fluid will fail to function properly in the transmission.
The Tow Haul mode is designed to keep the transmission's operating temperatures as low as possible when doing heavy towing or hauling.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
