CincyGus
Aug 05, 2013Explorer II
You will likely do ok if you have a southern facing campsite with it in your window. If not, you might struggle. If it were me, I'd try to mount close to a radio antenna or TV/Sat antenna use the same hole since your likely going to the same place.
Remove the dicor around it, run your wire, tape up with eternabond and then cover with dicor self leveling.
Screw the antenna through the roof into a truss and cover the same way. Eternabond covered with dicor seems to be pretty much leak proof from everything I have read about re-roofing or adding/replacing anything on a roof.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
