DonL100
Aug 13, 2013Explorer
Thanks Gus. I know that aluminum is non- magnetic. I was going to fasten a piece of iron to the roof with silicone but the main thing was the ground. The question is, does the antenna need to be grounded by the surface it is placed on? Or, is it grounded through the radio? Some magnetic CB antennas need to be grounded by the surface they are put on. For instance, if you put a thin piece of plastic tape on the surface between the antenna, the magnetic antenna will still stick to the metal but it won't be grounded. I hope this is clear. Thanks, Don
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
