TyroneandGladys's avatar
Jul 14, 2013
Slide out corner covers
Saw this today thought I would share. Instead of buying corner guards to protect your noggin from the sharp corners of an extended slide out the cut slits into tennis balls and slipped on the corners.
  • When my fifth wheel is parked at a friends drive, I placed a bright orange noodle on the sharp ends of the plate to prevent someone hitting their heads while cutting the grass in front while using a riding mower.
    It is bungeed around the plate.
  • downtheroad wrote:
    I have often seen folks using swimming pool noodles also.
    +1
    That's what I use. My bedroom slide is right at forehead height.... ask me how I know. :S
  • Pipe insulation for me. I wrapped it in white Duck tape for looks and slit the inside corner.
  • Tennis balls...good suggestion.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
