oakmandan wrote:
I am interested in using a basic solar panel with my camper to charge one or two 12V batteries. I would want to be able to run the water pump, a light or two and a 12V fan. Any suggestions of how to and what equipment I would need ?
Thanks, Dan
Dan, you don't say how long you usually stay out camping or what size battery (Batteries) you have but you may be able to just upgrade your battery bank and get where you need to go.
My camper came with a cheap, no name group 24 battery. I could go a couple days on that running water for dishes, 3 quick navy showers a day (one Each for DW, DD and I), listening to a little radio (3-4 hours) and running a vent fan at night to draw air into the windows and a couple lights for 2-3 hours a night.
Once I switched to led bulbs for the lights, I could go an extra day.
Once I switched to a group 29 battery, I could go 4-5 days using everything conservatively.
My point is, look at upgrading your battery to a larger size, or multiples (2-3 batteries) or going all in and going 4-6 volt batteries if you want an extended stay. Switching to LED's is worth the investment if you dry camp a lot. If that is going to give you enough power for your longest trip, buying 4 6v's for $400-$500 might be the better option than spending the same amount on solar. As conservative as your needs are, something to think about.
