Isaac-1
Dec 13, 2016Explorer II
The way mine is set up is a second small transfer switch wired inline that to a single 20 amp breaker on the breaker box and feeds 4 or 5 outlets around the motorhome (2000 watt Xantrex Prowatt SW inverter which is model without a built in transfer switch). The transfer switch in question is http://www.xantrex.com/power-products/default/inline-transfer-relay.aspx
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
