memtb's avatar
memtb
Solar Panel Upgrade
Thought that I’d share my recent changes made to my solar panels. We bought unit used, and panels were not adjustable for different seasons or different latitudes. So, I mounted perforated angle to panels and to roof. Purchased 3/8” aluminum rod, cut and bent 90’s on each end, drilled a hole in end of rod so a hairpin clip could secure rod into perforated angle to achieve the desired angle for your panels.
If you are a “boondocker” and want/need adjustable panels, this may work for you!
Having trouble with photos. Giant photos and tiny script. Will post pics separately. Sorry for the inconvenience.
  • I bought a kit for a panel that I use to power a camera on my property. It's too far to get utility power to it. The mount looks similar and I bet yours was probably 1/4 the cost. Looks good.
  • Here’s a closeup of the 3/8” aluminum rod, hairpin clips, and washers. If you look closely at the aluminum rod, you can see holes drilled for clips. Also note the protractor which is used to get the correct angle on the solar panel which will change seasonally or with a latitude change. If you choose to make adjustable panels, there are internet sites that can give you the angles required for optimum solar panel performance using your location and the time of year.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,382 PostsLatest Activity: Jul 24, 2025
