Blazing_Zippers's avatar
Blazing_Zippers
Explorer II
Apr 07, 2015
solar powered refer vent fan?
Does anyone have thoughts about using a small solar panel to power refer vent fans? Harbor Freight has a solar panel with plenty of output for up to three 12 volt fans ( I didn't buy it because it didn't say it was weather proof). Solar wouldn't use up boon docking power and would work pretty well most of the time.
IDEAS??
  • old guy wrote:
    it has been a few year now but I bought one from Camping World and within a few months it froze up, so I sent it back for a refund. I have since put in a small computer fan with an on/off switch
    X-2
    The power consumption is so low on the computer fans, I wouldn't worry about using my 12 volt system to power them. They are easy to find & cheap. Put a couple just inside the exterior access door, one at the top to draw air out & one in the lower section drawing in with a in-line thermostat to control them. Read up on the set points of the thermostat to get the right one.
    I just use a dual fan inside my refer with a on/off switch & wired with a fuse to the 12 volt on the backside of the frig. About $20 on Ebay.
  • it has been a few year now but I bought one from Camping World and within a few months it froze up, so I sent it back for a refund. I have since put in a small computer fan with an on/off switch
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 16, 2026
