dave17352
Jul 27, 2017Explorer II
hum I wonder if that disconnect switch connects your vehicle starting battery with your house battery so you could use its power to start your generator. Is it a spring loaded switch? The little loops are called ring connectors or ring terminals. :) If this is the case and the two wires run to your house battery you are good. If the two wires run to your vehicle battery you are not. Also right now you only have one 100 watt panel, as things grow you will have to be checking your wire gauge and length of run etc. Also it would be good to fill out your profile as the other poster said. May be someone on here that has been there and done that on your exact rig. JMHO
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
