gkainz's avatar
gkainz
Solar wiring route?
Thinking about dropping the solar panel wire over the edge of the roof at the awning, making a small drip loop on the side, then following the awning power cable to the basement. Shortens the run by about 20' over using the fridge vent and keeps me from dropping the belly again.
Thoughts?
  • In my last trailer I dropped it over the side and used plastic wiring channel which I stuck to the side. This went all the down and then I went up through the bottom with the existing holes for the battery cutoff switch. It looked good and you could do the same right beside the awning. This eliminated any Dicor or Eternabond and didn't need a drip loop as the water would go straight down anyways.
  • Look at this product on amazon
    Link Solar Weatherproof ABS Solar Double Cable Entry Gland for All Cable Types 2mm² to 6mm² for Solar Project on Rv, Campervan, Boat
    Link to Amazon page.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
