CR_CRUISER
May 13, 2013Explorer
aarond76 wrote:
I just pulled the wires off the little white adapters that came with mine, took the fixtures down from the camper, soldered the adapter wires to the switch on the fixtures and put them back up. Seemed easier and cheaper than busting the bulbs and soldering directly to them.
I tried that but I'm pretty sure that the wires in the white adapters that I received were aluminim. I couldn't get solder to stick to them. Instead of breaking the glass on the 1156 bulbs, I just warmed the base with a little butane torch and the glass came out. I unsoldered the wires from the small brass adapters and soldered them into the 1156 bases.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
