AimlessWanderLu
May 15, 2013Explorer
zmanmike wrote:
When I converted from regular 1156 bulbs to LED panels, I bought empty bulb sockets. No need to ruin good bulbs or risk getting cut. All you need is a soldering gun and some flux to solder the wires on. Just make sure which one of your LED wires is positive and negative so you can solder them into the correct locations.
This is what I bought. I believe you can find them at superbrightleds.
(..snip..)
Hope this helps.
I couldn't find the empty sockets anywhere, so I reverted to crafting my own adapters like many others. I don't seem to be able to find the empty bulb sockets at superbrightleds, either. :h
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
