westend's avatar
westend
Spare tire holder ideas
I need to install a spare tire holder. I have a welder and some steel so could fabricate something, not against buying one off-the-shelf, either. Where is the best place to mount such a thing? Looking for good ideas on this.
  • I might be tempted to rig something up on the tongue if there's room there. Since that's not an unheard of place for spare tires for trailers, there's a good chance some off-the-shelf holders would fit or could be made to fit fairly easily. There might not be sufficient room, though, while still giving proper access to the LP bottles and the jack.
  • THIS is the one I use. I mounted it to the rear TT bumper. It swings down & out of the way, so I can access my rear cargo door. I suspect your TT has a pretty strong rear bumper & may not need any additional support, but it's worth checking.
  • I would look into something like this. Your trailer sites pretty close to the ground in the photos of one on the net.
    You would need to check your rear trailer bumper to make sure it stout enough to handle the weight. Option would be to add a structural member between the bumper and rig between the frame rails.
    Tire carrier
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,387 PostsLatest Activity: Aug 16, 2025
