bloomis2925's avatar
bloomis2925
Storage compartment lights
I found some 12V LED light strips that I want to replace my front storage compartment lights with.
I plan on wiring them to a switch for on/off, but is there anything that I need to be concerned with since when the rig is plugged in, it would run off the converter?
I'm used to electrical wiring in vehicles, just not 100% sure on the converter.
Thanks!
Brian
  • The 12 VDC is provided by the battery. The converter maintains the charge on the battery. Not much difference as using your radio when you car isn't running. When your car is running the battery charged is maintained by the alternator. So in a way the converter and alternator do the same thing.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,387 PostsLatest Activity: Aug 18, 2025
