Old-Biscuit
Nov 30, 2020Explorer III
udaman wrote:
Thanks!!
Realized yesterday that I need a switch, which is sold separately!
So I’ve ordered the “on demand control Center” and not just the on/off switch (which is also sold separately) :)
That explains the connectors on the two grey wires (ODCC) and also the two LED wires, these four should connect the the switch.
And I am assuming the red and black wires will connect to the orange/white wires. (Old Biscuit, yes I didn’t mean “connected” , rather orange and white ...positive and negative, sorry about that. Lol
I assume the orange is positive and white negative?
Then there is the small green wire from the RV...don’t know what that is for.
And yes the 120 I won’t be using and I have terminated that into the junction box that was already there.
Orange should be 12VDC+
White should be 12VDC-
**Verify using voltmeter
Green would be GROUND
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
