wayfun's avatar
wayfun
Trailer step improvement
We use our trailer as a winter home in Florida and spend about 4 months a year in it. Last season we felt that the fold out steps were a bit unsafe. Even with a support jack under them they would shake when we went up and down and they seemed too steep and narrow. I searched the web for another solution that could be disassembled to pack away when we left. I found one idea that was essentially a series of boxes that stacked.
Since I was building them on site and didn't have access to a good saw to rip the lumber so I couldn't get a consistent step height when the boxes were stacked. So after further thought I came up with this design that has worked perfectly. I used 2x10's as the vertical supports with 2x4 and 2x6 cross members with 1" trex treads. I then tied the vertical sections together with door hinges on each side. When we pull out in the spring all I have to do is pull the pins from the hinges and stow each step away.
This setup gives me 5 steps, counting the step into the trailer, instead of 4. Each step is 7 inches. They are sturdy and you can go up and down without holding to the hand rail when you are bringing in groceries with your arms full. And the dog likes them too. Attached are my plans and a photo of the finished product if you have any interest.
Dennis
  • I thought I should further explain my logic for the design. We only use our traier in Florida as a winter home. We own a lot in a park that has RV lots as well as modular, mobile and stick built homes. I wanted a step that could be broken down to move and be small enough to be placed under a neighbors house for storage. The pieces could also be placed in basement of a 5th wheel or in the back of a pickup. I looked at some one piece fiberglass units that some people here use but they were too big move around. When we leave we must have everything on the lot put away and secured in case of a hurricane when we're not here. This design hits my design points.
    Dennis
  • Houston Remodeler wrote:
    Suggestion;
    Make the treads lock in by gravity, then put the center hinge on the other side and fold them like accordions.
    How would that work? Maybe I'm not understanding what you mean. I got the tread part, but what would fold?
    I think the OP did a good job. Simple (after you came up with a plan) and effective.
  • Suggestion;
  • We just installed the Glowstep Revolution on ours and absolutely LOVE them. They just replace the old ones, so they go wherever the RV goes and they don't take up any room.
    That does look good and very steady, though. Good job.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
