mowermech
Nov 10, 2013Explorer II
Transmission change
Can a mid-'90s 5 speed transmission be put in a 1977 Dodge W100 4X4; specifically one that has early '70s 3/4 ton axles, springs, and transfer case, and a 360 V8?
If so, what "special" parts would be required to mate the tranny to the engine? Will the existing transfer case bolt to the tranny, or should a transmission/transfer case assembly be procured for the swap?
The reason for thinking about the swap is to get the overdrive to offset the 4.1 gearing of the 3/4 ton axles.
