RedRocket204
Oct 04, 2015Explorer
mbopp wrote:
The solution could be as simple as re-positioning the bracket on the bed base to allow more leverage for the existing gas spring. But this will reduce the compressed length of the spring, check carefully that you don't bottom it out.
Exactly. Increased leverage will hold more weight. Probably no need to purchase stronger support shocks.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
