Hi,
Most medium base LED's are set up for AC electricity, with a built in circuit to change it from AC to DC power. Normally that means it will not accept DC power.
What I did in my RV is disconnect the wires to the old blub base, then connect those 2 wires to a LED panel base. Then this plug can accept one of the panels, so I put two panels in each side of the factory installed twin light fixtures. So I can run 2-4 panels - say in the bathroom where I wanted a lot of light. This is only 0.4 amps, and with a 400 watt solar system, I sort of wasteful of power! It is nice!
Check out this type of panel too.
http://www.aliexpress.com/store/product/Free-shipping-COB-Chip-LED-24led-smd-Car-Interior-Light-T10-Festoon-Dome-Adapter-12V-Car/211920_1705672704.htmlIt is super bright, and only 4 watts! Because the LED's typically put out about 10X the light of a incandescent light, that would be equal light from a 40 watt regular lamp.
THis one will replace a 1156 bulb, and use the factory base.
Clicky 2Fred.
