Golden_HVAC
Jul 02, 2016Explorer
The first thing I would check is measure the voltage between the A/C circuit breaker and the white wire bussbar. If that is 120 volts, and the A/C is still not working, you may have a problem with the A/C or it's thermostat.
Of course if you only have 100 volts, that is the problem.
Good luck!
Fred.
Good luck!
Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
