time2roll
Jul 02, 2016Nomad
Golden_HVAC wrote:+1 right here
The first thing I would check is measure the voltage between the A/C circuit breaker and the white wire bussbar. If that is 120 volts, and the A/C is still not working, you may have a problem with the A/C or it's thermostat.
Of course if you only have 100 volts, that is the problem.
Good luck!
Fred.
Post the voltage on the air conditioner branch circuit breaker.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
