DaHose's avatar
DaHose
Upgraded gas water heater to electric
Today I finished installing and tested my new CAMCO Hybrid Heat electric conversion for my water heater. It works just fine, but it does take a very long time to heat. The element is just a little 450 stick that threads into the drain hole.
I looked closely and confirmed that the thermostat relay in the kit is rated up to 120V, 25A. Then I looked around and found that CAMCO makes a 120V, 1500 watt element that can thread into the large anode rod hole. The new element should run at about 12.5A and is well within the operating range of the thermostat relay. I also used 14GA wire everywhere, so I should have no problem powering the larger element.
Jose
  • beemerphile1 wrote:
    Does the element also act as an anode or are you just sacrificing the life of the tank?
    I just did this upgrade on my Atwood tank, and it's well worth the effort for a full-timer. Since the Dometic doesn't have an anode rod to begin with this issue was not a concern.
  • With the supplied parts in the kit, you are supposed to replace the drain valve with the small 425 watt element and run a regular sized anode. The larger element would replace the anode, so looked around and I found a company that makes a 1/4 and 3/8 anode.
    My end result will be larger element in the anode plug and replacing the drain with the small anode.
    As a side note, my tank does have two large anode ports. One in front and one in back, above the circuit board. However, the front side anode was galled and took a breaker bar to remove. The rear one looks like it was plugged at the factory and hasn't been pulled since. I tried the breaker bar on the back one and the whole tank wanted to turn. I am afraid to put an impact on it and break the tank, so that is why I hunted down the smaller anode. If I could have pulled the larger plug on the back, then I would have just put the heater element in there and left the front with the regular anode and drain valve.
    Jose
  • Does the element also act as an anode or are you just sacrificing the life of the tank?
  • Roy You do NOT want to run any resistance heat from your battery, it will suck it dry in very short order. I have a 25lb tank which holds 6.76 gal, a conventional 20# tank holds 4.6 gal. To heat our teardrop I have an Espar diesel heater that uses very little electricity and not a lot of fuel.
  • RoyB's avatar
    RoyB
    Explorer III
    I will be doing something similar when I start experimenting with my HYDRONIC Heat mod for my OFF_ROAD POPUP setup that will use the hot water heater for heat source replacing the propane furnace..
    I want to be able to run my hot water heater from my on-board INVERTER for a PLAN B backup when PROPANE may not be available...
    I will probably go with a smaller wattage 120VAC heater element however...
    Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
